주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
20 질문 전체 보기
Single black vertical line down display
So as the title suggests, I have a black line down the display now.
This is self inflicted as I’ve just had to chop the whole bloody thing apart to upgrade the RAM and swap out the disk for a SSD - which all works fine btw, no issues there - but the end result has been this black line down the display.
It doesn’t appear in screenshots nor on my second monitor so it’s isolated to the display or the display data cable. I’ve tried flushing NVRAM and I’ve tried looking for any discernible breaks of blemishes in any of the cables or circuits… nothing.
Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Ouch! You did your self in ;-{
In the process of removing the display you damaged the LCD panels connections along the edge. If you had gotten the special adhesive cutter which is part of this kit [링크된 제품이 누락 또는 비활성화 됨: IF173-005] it would have likely saved you.
Time for a new display assembly!
And here’s the the needed guide iMac Intel 21.5" Retina 4K Display (2017) Display Replacement
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
I certainly did... ironically I did get a kit like that, it wasn't a pizza cutter though more like a little stanley knife.
I had a feeling that I'd busted the display, I have a replacement on on order now, the full unit - https://www.amazon.co.uk/gp/product/B07G... - but I've also got the display cable on order so was wondering if I could get away with just replacing that... I guess not!
Thanks for taking the time to answer.
If you are careful you can transfer the cables over. Do re-order the needed adhesive strips! make sure you've fully cleaned off the old adhesive and clean the surfaces with reagent quality isopropyl alcohol (85% or better) Drug store alcohol is junk!
Yeah I've scraped off all the old adhesive, but a rubbing is a good call so will get hold of some of that. Thanks.
Incidentally, this was the kit that I bought and used for this disassembly. I guess the cutter just went in too deep. https://www.amazon.co.uk/gp/product/B01M...
@Paul Aldred-Bann - Ah... The knife was not the correct tool here ;-{
Did you review the guides before you started??
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Paul Aldred-Bann 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 36
전체 시간: 4,064
