주요 콘텐츠로 건너뛰기
AirPort Time Capsule은 network-attached storage (NAS)/네트워크 -결합 저장 공간 및 가정용 게이트웨이 라우터를 제공하는 무선 네트워크 기기입니다.
25 질문 전체 보기
If I can, how do I replace the HDD with a SSD
If i can, how do I replace the HDD with a SSD in my Time Capsule? After all an SSD would be much faster.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 2개
Also, will the SSD even effect the speed of my backups or will it stay the same? I was hoping that it would make my backups faster
It won't hasten anything as you're bottlenecked by the connection interface from the logic board.
댓글 달기
답변 2개
선택된 답변
  1. Physically connect the SSD. Place the SSD in the enclosure or connect it to the USB-to-SATA adapter, and then connect it to your laptop with the USB cable.
  2. Initialize the SSD. ...
  3. Resize the current drive partition to be the same size or smaller than the SSD.
Hope this is helpful!
Regards,
Lewis
Admin
Apps4rent | o365CloudExperts
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Great thank you!
댓글 달기
가장 유용한 답변
Replacement HDD larger than 2 TB?
May be this helps. SSD will improve the speeds provided you have SSD on your laptop/desktop so that it can send data QUICK.
also any wireless backup will depend on your wireless router.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the info!
댓글 달기
귀하의 답변을 추가하세요
Strider 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 28
30일 전: 155
전체 시간: 5,974
