주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The first generation Forte shares the same platform as the Hyundai Elantra (HD), though employing a torsion-beam rear suspension in place of the Elantra's multilink design.
Trying to locate & fix thCamshaft Position Sensor on 2012 Kia Forte Ex
For the life of me I can not locate where the Camshaft position sensors are. I am told there are 2. Can someone please help with a detailed description on where I can find these?
Update (11/09/2019)
이미지
Oldturkey03 is wrong
I could not find the camshaft position sensor on my 2012 Kia Forte Ex and there is nothing online. But I found it finally. Here is the camshaft position sensor. And this car only has one. Again this is for a 2012 Kia Forte Ex. You have to remove the plastic piece from the top of the engine and the tube going to the air filter to gain access to the camshaft position sensor. I am pointing to exact part on the engine. You have to remove the plug and then wiggle your way to take off the screw, pull it, and replace with the new one. I used a 10mm socket. I hope this helps someone else cause there is NOTHING online for this exact car….until now
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 5개
My 2012 kia optima starting and dying. Anybody who can help preciate ya?
Actually, this car does have two if you look directly behind that one on the opposite side of the motor you'll find the other one and by opposite side of the motor I mean close to the firewall. The one that you're pointing at in the picture is the intake camshaft position sensor the one close to the firewall is going to be the exhaust camshaft sensor. I only know this because I literally just changed this on my daughter's car two days ago. Hope this helps
My obd11 meter is saying it need a camshaft/crankshaft pos sensor b there's a part a and part B the auto parts guy was telling me there is 2 of them for cam n crankshaft is a different one my car will start and won't idle it will sputter n die unless I give it gas can I just replace the one sensor the oxygen sensor since I don't have a whole bunch of money
Would this throw a p0014 code cuz my 2012 Kia Forte ex 2L is
@soulman396 If you get a code, the auto place should be able to run the code and tell you what to replace
댓글 달기
답변 2개
선택된 해법
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 5개:
You are absolutely right. My chart was for >2014
Kia forte ex 2012 have 2 position sensor
On the left side from the oxygen sensor you need remove 2 pieces of metal then you can remove the sensor
This come with long connections and go to the top on the motor
Oxygen sensor and cam shaft sensor are not the same..I've replaced both. One is called an Oxygen sensor and the other is a camshaft position sensor
He's right there is only one camshaft position sensor..... If there was 2 it wouldn't be away from the camshaft. Hence the word camshaft
But you do have camshaft position sensor and crankshaft sensor not to far from each other,
댓글 달기
I was told that if you have a federal emission engine, you only have 1 camshaft sensor, the California emission engine has 2, one on each side of the engine.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The information I gave about this specific car is correct. The is one cam shaft and a crankshaft on the other side
댓글 달기
답변을 추가하세요
Ray Borrego 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 34
지난 30일: 113
전체 시간: 12,943
