주요 콘텐츠로 건너뛰기
Why does power go off immediately after turning it on?
When the laptop power is turned on, it goes off immediately. Have changed the battery and charged for days and no difference. What could be wrong.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 14
댓글 4개
i have a HP probook 6470B when i put the battery i hear the fan comes on for few seconds then shuts off , again it keeps repeating the same until i take out the battery and every dies , any help would be appreciated
My laptop Compaq Presario CQ61 has the same issue, it goes off immediately after power on
turn on then turns off problem
Hi my hp pavilion dv7 that I use for school turns off immediately leds and fan turn on for 1 second and shuts off can eneyone help me
댓글 달기
답변 2개
선택된 답변
Eddie, this particular series has its fair share of problems. For example, there is the dreaded BIOS F39 issue which cause absolute failure and is a firmware issue that, most of the time, will require motherboard replacement. Then there is the overheating issue. The design of the laptop delivers poor ventilation and causes the computer to overheat. You can try something similar to a hard reset. This is simply to remove power from the laptop. Remove the Battery. With all removed from the laptop...hold the power button down for one minute. Then release the power button. Plug in the battery first...then the power cord. Try powering the unit up again. This reset will not do anything but do a Hard reset on the machine. If none of that works, It might just be time to further investigate and to open the laptop up. you definitely want to clean it of all corrosion and especially dust in the vents and around the fan. Make sure that the fan works since a bad fan can cause this error as well. I do hope this helps and at least gets you started. Good Luck
The service manual is available here.
해당 답변은 도움이 되었습니까?
점수 11
댓글 3개:
Thanks OldTurkey, I've pressed power button for more than 1 minute without battery and now it's work again.
Iena Plinsky, you are welcome
Removing the power sources and holding power button, then replacing all as instructed worked for my hp dv6. Thank you so much @oldturkey03 !!
댓글 달기
my laptop turned on for a second or two but then turned off. when i started it up it showed the hp logo an before i could do anything the laptop turned itself off. sometimes i would turn the laptop on and it would go into windows repair mode, i noticed at this point the laptop would stay on for about 30 seconds or longer before turning off.
The charger was the issue with my laptop. when i first got my new charger and tried to turn the laptop on it would just restart within 1 to 2 seconds of turning it on. i did all the hard reset resets but it was still the same it would keep truning off. i then left the laptop on charge for about 15 minutes before returning to it and when i pressed the power button the laptop started up and went into windows repair mode, when it did its repair thing it just asked me to restart the laptop or go into advanced option. i restarted the laptop and it started up first time, it hasn’t turned off on me yet so i hope its been fixed.
hope this helps others too.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
yes I have this problem too
I have this problem as well. I remove the battery, unplug the power, and then press the power button for a minute. This did not fixed my issue. Next I will try testing the fan and see if it works. We'll report back here after
댓글 달기
귀하의 답변을 추가하세요
Eddie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 51
전체 시간: 75,849
