iPhone 7 water damage not turn on
Hello. I have a problem with the flooded iPhone 7, it had a short circuit of 0.350a I was able to remove it now it is 0.000a after turning on nothing happens and stands at 0.060-0.080a. Have any ideas?
좋은 질문 입니까?
좋은 질문 입니까?
you need to clean it using isopropyl alcohol. that will involve completely disassembling it.
iPhone 7 Rear Case Replacement (you do not have to replace the rear case, but this guide will go over complete disassembly.
해당 답변은 도움이 되었습니까?
pcb I already cleaned in an ultrasonic cleaner. A few capacitors fell in and there is no pmbb layout because it was short
halo cześć,
0,06A przy starcie wskazuje na niski bilans energetyczny. W takich przypadkach warto przestudiować linie główne zasilania. W większości przypadków, jeśli ich parametry mieszczą się w normie szukałbym “korka” za PMU. Sprawdź porty LDO z MPU i CPU razem z liniami SOC. Niewiele dalej, bo od 0.09 zaczynają się spięcia pod procesorem, spowodowane przegrzaniem 7-ki przy zdejmowaniu shield’ów.
pozdrawiam,
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 63
