LG37LC2D no internal HDMI connection
So someone was getting rid of this tv. I plugged it in and it looked like menus and everything worked, So I attached HDMI.
nothing.
so I opened it up.
it looks like there was NEVER an internal ribbon cable from the board to the HDMI connection.
is this common? If I find and hook up a cable correctly, will it work? Or is it not made for HDMI and the default solder points just standard and the HDMI port is just to close the hole in the back?
좋은 질문 입니까?
댓글 2개
Hi @the_shoffer , so the HDMI ports are not connected with the PCBA? They are only placed in the chassis without connection?
Lucas 의
@the_shoffer post some good pictures of your boards as well as the interconnect cables etc., with your QUESTION! That way we can see what you see. 기존 질문에 이미지 추가하기
oldturkey03 의
