주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
140 질문 전체 보기
What screwdriver do I need to open the battery panel? MacBook Air 2015
I spilled a little vinegar on my laptop days ago. I’ve just got the right screwdriver to open the back of it but I’ve discovered that I need two different screwdrivers to open the battery panel. Where can I get this in stores! Please help! Thank you. MacBook Air 2015
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Here’s the iFixit guide you need to follow: MacBook Air 11" Early 2015 Battery Replacement
You need the following screw drivers:
T5 Torx Screwdriver 이미지
상품
T5 Torx Screwdriver
$5.49
P5 Pentalobe Screwdriver Retina MacBook Pro and Air 이미지
상품
$5.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
My laptop isn’t turning on. Do you think the batteries are just the problem? Where do I get new ones?
Before you jump into getting a battery. How about doing some basic tests.
When you plug in your charger what color is the MagSafe plug Amber or Green?
If the charger is not lighting inspect the contacts for damage and clean the contacts if needed.
Is the charger the correct one for your system?
The charger lights up when I plug it in. It turns from green to amber. I don’t want to start my laptop again because it shortens it. When I start it it turns on and then shuts down real quick. I can’t believe it’s not working. When I spilled a minuscule of liquid on it and wiped it up right away. I don’t see any corrosion inside nor any liquid. I don’t know what’s the problem. If you could please help me thank you
댓글 달기
귀하의 답변을 추가하세요
aimee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 8
7일 전: 46
30일 전: 167
전체 시간: 7,076
