My camera wont stay on.
The camera comes on, the green light on the back flashes once. The lense starts to come out, then immediately retracts followed by 3 beeps.
좋은 질문 입니까?
좋은 질문 입니까?
First, a easy fix, charge the battery overnight, put it in, power it up, if you yield the same result, replace the battery and see what happens
I will update this after we have more details on what happens and what you did to troubleshoot
해당 답변은 도움이 되었습니까?
I think the answer is in the question Read the second sentence carefully....
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,649
댓글 6개
I go with a stuck lens. It can cause errors the way you described yours. Check on here for more info
oldturkey03 의
I'd agree with oldturkey, it's a good link too
pollytintop 의
Hi there
I'm sure you have problem with lens of camera . is not that eays to be fix by ur self if you don't have exprince on repair camera but you can try .
you have to know some time after fix it stil you have problem that is u can see line on you lcd screen . is mean you have change your lens .
I do repair cameras .
cyrus 의
Hi there
I think you had problem with lens Of your camera ./ maybe you dropprd your camera.
cyrus_7029@yahoo.com
cyrus 의
I seem to be having the same fault with my Samsung L100 camera. I fitted a replacement battery and still the same fault is present
Sean 의
댓글 1개 더보기
