주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4941 질문 전체 보기
iPhone 6 Won't Charge. Replaced Battery.
I recently started getting into phone repair as a small hobby. I got an iPhone 6 from a friend that will not charge. I replaced the battery and it booted up just fine. When I plug it in, it turns on but does not charge. Did a hard reset and the charge port seems to be clean. What is my next step in repair? Should I replace the charge port? It will not connect via the charger.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
You need to rule out parts first. Try another dock and if it still will not charge you will have to replace the Tristar IC.
 If you are getting into IPhone repair this is the most common problem you will encounter. Check out some YouTube videos so know what equipment you will require.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
That is your dock connector (Lightning port) if this does not fix the issue it will be a board level repair which most likely can include micro soldering. Good Luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Chandler Bohnen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 36
