주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
253 질문 전체 보기
Screen color distortion, flickers
Hi everyone!
I’ve got a problem with my book:
Display doesn’t work fine — screen is flickering a little bit, colors are distorted. Sometimes there’s even blackscreen.
However, there is important note that it works fine only if macbook is open fully or is open at approximately 45 degrees.
Screens:
https://drive.google.com/open?id=1POYzqw...
PRAM reset didn’t help, btw.
Also I can’t change it bcs it’s 15’ and it is not a screenstage.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Sadly your display cables have become damaged! This is a similar problem we saw with the FlexGate issue which was a different ribbon cable in its case it was a bit short so it got stressed. In this case you likely banged the clutch cover just at the right place to kink the cable so over time it fatigued.
Here’s a view of the cables
You’ll need a new display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 15" Touch Bar Late 2016 Screen Replacement
MacBook Pro 15" Retina (Late 2016-2017) Display Assembly 이미지
상품
$549.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Hi,
can I change the flex cables without buying a whole new display?
Sorry no ;-{
The cables go directly to the LCD panel you need very special equipment to bond the cables on .The lid is also glued together and so taking it apart would be close to impossible without breaking it. And lastly, were are you going to go to get the cables? They are not available either.
Ah, that sucks!
I read about changing the LVDS flex cable which is available for ~10€ on eBay and my hope was that this would fix my issue. Or at least I try this before investing hundres of euros.
But I guess I'll watch some display replacement videos to see if I'm capable of repairing it myself.
@larrygrabb - The new Touch Bar systems are the least repairable MacBook Pro's yet! Its all most a 2~3K throwaway system ;-{
I'm sure the coming Apple Silicon systems will be!
댓글 달기
귀하의 답변을 추가하세요
alexander 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 2,180
