주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2177 질문 전체 보기
Orange marks on LCD when certain clips are in
Hey, so I did a screen repair on an iPhone recently. It went fine, and before I reconnected the clips holding in the screen I tested it to make sure it was fully functional, which it was. I got busy and left it open for about a month, then I came back to it, made sure it got a good clean, and closed it. Booting it up I noticed a small orange spot on the top right corner, and whenever the screen was displaying a dark colour the edges in that corner would be very light. I opened it again to see if that would do anything since it was working fine before, and with the clips not attached it was normal again. I repeated this a few more times to confirm, and I kept getting the same results. Then I narrowed it down to which clip was causing it to go from normal to discoloured, and to my surprise it was one right next to the battery. I’ve never seen this before so I have no idea what to do. Could someone help me out? Thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
Is there resistance when youre putting the screen down? Is it possible that the clips aren’t quite sitting right and its putting pressure on the LCD?
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Jasper Holden 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 21
