iMac won't turn on
It does not work, when opening the iMac from the inside, I found that when I press the power button only the fans turn on and then turn off
Update (12/08/2019)
Only LED #1, what’s the problem now please
좋은 질문 입니까?
좋은 질문 입니까?
In the bottom left corner of the logic board is a strip of tape covering over the onboard diagnostic LED’s. Carefully remove it so you can see them. Tell us what you see.
Here's a breakdown of the onboard diagnostic LED's:
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 71
댓글 1개
Did you try a new PSU? As stated under LED 2.
Dan 의
