주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
869 질문 전체 보기
Why is phone 8 touch screen not working when home button is plugged in
iphone 8 touch screen not working when home button is plugged in. But when i remover the home buttom cable touch the screen works. the connections look clean.
I replace the screen with an original Apple screen. Even tried the original screen that the iPhone have still have same issue
I don't know if it's on motherboard issue I'm assuming it is
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
This is one of the common problem shown on the iPhone 8 Plus.I also faced that problem and i solved it.That problem is actually from the pin name display to MAMBA MSYNC CONNECTION pin problem.If you still stuck on that problem that is extremely helpful for you.Before doing you need some knowledge about micro soldering.Do that job carefully.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Plz help me I am stuck in this formate and how do I solve it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
isaac castro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,199
