I'm Stumped! Battery is Not Charging. Power Source: Power Adapter
The MagSafe light mostly stays dark (but see below).
Here’s what I’ve tried:
- Tried a different (known good) charger, with the same results.
- Verified that both chargers work on another Mac. they do.
- Checked the pins on the charger; none are stuck.
- Checked the MagSafe plug on the Mac; it’s clean with no signs of corrosion
- Tried several SMC resets. Sometimes (not always) the light flashes green continuously until the Mac powers on, then the light gets dimmer and goes out.
- Disconnected and reconnected the battery.
Here’s the the AC Charger Information from both good and bad Macs
Good Mac:
Bad Mac:
Both System Info and coconutBattery report that the battery is good.I’ve run out of things to test.
Suggestions welcome!
좋은 질문 입니까?
댓글 2개
Can you post the CoconutBattery snapshot so we can see it.
Dan 의
Can you boot into MacOS or Internet Recovery? In Terminal, try running [ pmset -g batt ] and it should report the charge status of your battery. What does it say?
QuincyMB 의
