주요 콘텐츠로 건너뛰기
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
384 질문 전체 보기
Ripped off power supply from motherboard. Is this fixable?
So I ripped the power supply adapter off the motherboard and I couldn’t find any other person with this type of problem. There are no soldering points, and I need to know if this is fixable or if the motherboard is just trashed. Thanks for the help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Yes this can be repaired, but not easily unless you have experience. The pads must be repaired before the connector is reattached. Also, there will need to be additional support for the connector otherwise it will easily be torn off again. This is not a repair that should be attempted without prior experience. Contact a local repair show and bring along the connector and the board (in a static bag).
Dan
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Richard Chatt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 435
