주요 콘텐츠로 건너뛰기
Apple의 PowerBook 노트북 라인은 전문가와 파워 유저를 위해 만들었습니다. PowerBook 라인은 PowerBook 100, Duo, 500 및 5300 Series; PowerBook 1400, 2400, 3400; PowerBook G3, G4 Titanium 및 G4 Aluminum으로 구성됩니다.
1017 질문 전체 보기
질문 마감됨
What does it mean if it starts making a noise?
I have a power book G4 and it started making noise on the bottom left corner of the keyboard. After it started doing that it an really slow until not working at all...What could this be and can it be fixed and if so will I be able to see what is in the computer?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
Back up your hard drive immediately. Your user files first. Your hard drive is going out. It's easily fixed with a new drive.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Your powerbook uses a ide hard drive. For performance increase go to a 7200 rpm drive.
If you can tell me exactly which PowerBook you have I can direct you to a repair guide.
댓글 달기
Sounds like a drive going bad, as mayer said, and you should backup your drive, however you should also verify and see if you can repair your drive with Disk utility. Though this sounds very physical.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
  • I have a powerbook pismo when I hit the start button I hear noise, but nothing appears on the screen.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 1개:
Post this as a new question.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 645
