주요 콘텐츠로 건너뛰기
Why is my dryer not heating and the inside light is off?
I have a Maytag drying center with an upper and lower drying chambers. The light in the lower portion is not coming on and I’m not getting heat above or below. I took the light bulb out and it doesn’t look like the element is broken. Does this model have fuses or do I possibly have a bad bulb and heating element?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@macsbabygirl71 double check the power going to your dryer. It should be 240V. If not then check your fuses/breakers in your panel. No, the dryer will most likely not have fuses. We will need to know the exact model so as to provide you with more repair options.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
macsbabygirl71 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 111
