주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1623 질문 전체 보기
Stuck in a boot loop
My computer is stuck in a boot loop. As soon as the battery is plugged in the fan turns on, computer chimes, fans stops, fan on, chime, and so on. The screen remains black throughout. I have replaced the logic board, RAM, and battery all without any improvement. Resetting the SMC and PRAM did not make any difference. If I unplug the ribbon cable from the keyboard, plugging the battery in does not start the fan or the chime, however with the cable unplugged I can’t turn on the computer at all. What do I do next?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 6개
What happened at the start of this? Did you have a liquid spill? Or drop, bang your system?
Does it work OK without battery? as @danj asked what happened?
The computer was turned off at night, I tried to turn it on the next day and this was the result. No drops or spills that I am aware of. It does not work with the battery disconnected either.
@carl2
What color is the MagSafe chargers LED Amber or Green? If Ambor let it charger for a good 8 hours did it get to Green?
The charger light did change to green after several hours charging. Boot loop solved with new keyboard, but the screen does not come on at all now.
댓글 1개 더보기
댓글 달기
답변 1개
선택된 답변
Since you have the same problem after replacing logic board, which is the Mac heart and brain, it sounds like one of the modular components might be the issue. Disconnect all and everything from the logic board, battery included and plug in the magsafe and you should see the board starting up, unless you have a faulty magsafe or logic board.
If that happens, reconnect components to the board one by one, always disconnect magsafe first. That should be enough to pinpoint what’s preventing normal functioning.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Thank you, following your instructions seems to show that the keyboard is the problem. I will report back after installing a new one.
New keyboard solved the boot loop problem. New problem is the screen does not come on at all. Brightness button makes no difference.
Hook it up to an external monitor and let us know what you get.
Worked on external monitor but was very slow to react and kept freezing. After turning the computer off, it will not turn on anymore.
Hooked logic board up to an external monitor with with nothing else connected besides RAM and fan and it gave the blinking question mark folder. Connecting either of two hard drives results in it refusing to turn on at all. I know for sure that one of the drives is good.
댓글 달기
귀하의 답변을 추가하세요
Tyler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 241
