주요 콘텐츠로 건너뛰기
Guides for the LTE version of the iPad Mini 4—model A1550. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
iPad mini 4 home button replacemnt
I’m repairing an iPad Mini 4 LTE that had a demolished screen - to the point where the wake/lock sensor and home button were almost non-existent.
I’ve installed the replacement screen and home button and was able to get into the settings and turn off the wake/lock feature to get around the need for the sensor. The home button works (no touch id of course), but the bracket isn’t quite stable enough - I used the double sided red adhesive that is normally used on the frame.
What is a standard adhesive to use with the home button brackets (short of using super glue)?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I usually use a good quality tape, either the 3M or Teva tape and then apply a bead of two-part epoxy around the bracket to give it a more solid feel. This is what’s done now right from the factory.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Bill Shannon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 152
