주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
161 질문 전체 보기
Can this MBA 2017 Logic Board be repaired?
Liquid damage. Cleaned with 99% isopropyl. I think I have narrowed down the possible problem to the chip shown in the red box in the pictures.
I am wondering if it is possible to fix this logic board as the chip appears to have “rusted” connections.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
Liquid damage is always tough to fix as you often have multiple issues that you need to work out.
I would recommend trying to find someone local who has the skills and tools to fix your logic board. As you can see referencing the MacBook Air 13" Early 2015 Teardown which is the same basic board as your system you can see some of the damaged/missing components you’ll need to source. I’ve flipped the image around so you can reference it to your pictures correctly. The light Blue chip is the SMC chip which is chip you have focused around.
So then the next question is will it be cheaper than just replacing?
iFixit is currently out of stock on the 1.8 GHz version of the board. Here’s an alternate source from TheBookYard in the UK, they also have the premium 2.2 GHz version as well.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Paul 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 22
