주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
135 질문 전체 보기
What keeps the front camera microphone grill waterproofed?
I spilled a sauce on the top portion of my iPhone 11 Pro Max on the front facing cameras and the microphone and i cleaned it all off with isopropyl alcohol at first.
But now I am afraid that the alcohol will affect the water resistance of the microphone.
So what are the speaker grill, earpiece grill and microphone grill waterproofed with?
It seems to be working fine and working well. I just want to know for future reference.
Thanks so much!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If you cleaned it with alcohol, you might actually have destroyed it.
The top speaker opening of the phone does not block water ingress at all. Ingress protection is achieved with a duct secured to the glass with adhesive, then the speaker plugs in to the duct, there is an o-ring preventing water leaking through the plug into the phone. The speaker chamber is sealed, water may get into it but that’s it, just let it drain back out. The microphone is adhered to the duct, but it occupies a separate hole. The adhesive prevents water leaking out the sides.
The adhesive is probably less than a millimeter wide in some areas and alcohol may dissolve or weaken it.
The actual way to confirm whether there are leaks is to do a vacuum test, which is more complex for iPhone XS and later because the barometer is not in the sealed case, rather it opens to outside pressure via one of the bottom grills, so it is not possible to use it to test for pressure changes inside the phone when you squeeze the case, a special fixture may be needed to test.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Man, I cleaned my #iPhoneXS way back in 2018 only to find that Hey Siri stopped responding then a warranty replacement
These Front Microphones are never water ingress protected.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Frederick Tran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 25
전체 시간: 1,104
