Replacing Front Glass ONLY,
How Hot does the front glass have to be to starts to separate from LCD?
좋은 질문 입니까?
좋은 질문 입니까?
The point I was trying to get at is glass only on OLED is nearly impossible because of how fragile it is.
해당 답변은 도움이 되었습니까?
The pixel 2 uses an OLED panel, which are SUPER thin. Anything with an OLED panel is unfortunately very difficult to do a glass only repair on with a very high failure rate.
해당 답변은 도움이 되었습니까?
So how many degrees C° should I set my LCD separating machine at if it's OLED ?
해당 답변은 도움이 되었습니까?
But it can be done right? Try using cold instead of heat,or would that matter when dealing with fragile OLED screens?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 596
