주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
260 질문 전체 보기
MacBook Pro 15 late 2016 no backlight
Hey guys,
the backlight on my laptop doesnt work. I tried pram and sms reset but nothing worked. When i put a flashlight on the display i see that he booted up and i can also plug in a external display and it works. Any ideas for what i can do? I read that maybe somethings wrong with the connectors on the logic board. The laptop was never wet and never falled down.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 2개
가장 유용한 답변
Sadly, your backlight ribbon cable has failed. This is a cable that runs between the system logic board to your display
This is a common issue on both the 13” & 15” 2016 & 17 models. Most people know it as FlexGate 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists. Apple did create a extended warranty program for the 13” models 13-inch MacBook Pro Display Backlight Service Program. You’ll need to plead your case at an Apple Store to get a warranty exception which some people have managed to get for the 15” models. You’ll likely need to work up the food chain within Apple from the Genius, service manager, store manager(s) and then to the regional manager(s).
Your other option is to just get a new display assembly. Here’s the guide: MacBook Pro 15" Touch Bar Late 2016 Screen Replacement
If you know of a very good micro soldiering tech the damaged cable can be replaced its not easy! Here’s the cable https://www.ifixit.com/Store/Mac/MacBook.... I failed on my first attempt!
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Thank you very much! I read about this flexgate issue so i will try to contact the apple store to see what they will tell me.
I would just walk in Vs calling. I often find the telephone support folks tend blame you instead of being helpful getting you an appointment which is all they should do here.
Do you know if they will replace the display with the newer one from 2018? Or will i get the same 2016 Display which can cause the same problems one year later?
You'll need to ask Apple that!
What I can tell you is Apple rev'ed the part to 661-08030 from 661-06375 for the Space Grey part and to 661-08031 to 661-06376 for the Silver so clearly something changed!
Ok thank you!
댓글 달기
I also have a 2016 15" MacBook Pro with this problem, however, the lid has been closed less than 10 times in it's lifetime so I don't think it is related to FlexGate. Could this be caused by anything other that the $750 fix?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The angle of the lid plays into this so it still could be! The only way is to have someone with the deeper skills inspect the cable for damage
댓글 달기
귀하의 답변을 추가하세요
Lukeatthis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 28
전체 시간: 6,523
