주요 콘텐츠로 건너뛰기
2018년 9월 21일 출시. Models A1921, A2101, A2102, A2104. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S Max"로 발음합니다.)
373 질문 전체 보기
Ear speaker/Loud Speaker/Mic Not working
Ear speaker and loudspeaker not working on phone call mic sounds funny too!
Did screen replacement on phone not sure if the phone had the issue before the screen was broken!
I did a force restart and sound starts to work but then cuts out anyone knows what I am supposed to do next?
When you push speakerphone button it will sometimes shut it off
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It’s always important to fully test a device before attempting a repair. If you don’t do this, then you’ll never know if the problem was pre-existing or if it was caused by faulty replacement parts or mistakes in the repair itself. It’s not clear if this is a repair you were asked to do for a customer (or friend/family) or if you are buying/selling used phones. It doesn’t change the problem but it does affect solutions moving forward.
Start by re-installing the original screen to see if the problem is consistent or not. While you’re at it, double check your work by following this guide. Take a close look at all the flexes; you want to see if there are any tears (however small) or damage to the connectors. Also insure that all of the connectors are properly seated because the ear speaker and loudspeaker are on completely different flexes but the connectors are relatively close to each other on the logic board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Old Screen is shattered beyond being used! Cant test phone must be another issue I could try ear speaker flex but why wouldn't speakerphone work if the ear speaker is broken
My customer brought it to best buy they are apple certified said that it needed to be programmed... I programmed the OLED but never heard of an ear speaker needing to be programmed did they lie to my customer
Just checked the iFixit Store. Here is what they say:
NOTE
The Earpiece Speaker and Sensor Assembly is paired to the logic board. This assembly contains the flood illuminator, which is part of the Face ID security feature. Replacing this assembly will not restore Face ID functions.
댓글 달기
귀하의 답변을 추가하세요
Mark D Schlossman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 3,695
