주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Is there anyway I can make my phone make calls again?
I have an Iphone 7, that doesn´t make calls, like, when I look at top left corner It says “No service”. What is wrong with my phone? An anthena? Is there a anyway I can replace it?That´s what I need help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Are you paying for service through a provider?
What does that mean?
댓글 달기
답변 1개
선택된 답변
If the antenna wire is connected properly from the dock connector to the motherboard you can rule out an antenna issue. The no service on the 7 series usually is a result of an audio IC repair which has had too much heat applied. The baseband IC is underneath the audio IC and is under filled, too much heat causes solder balls to bridge giving the searching no service.
Flexation or a heavy drop can also damage baseband. The baseband CPU will have to be removed and reballed. It will not be a cheap fix.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Uhh, I don´t understand what did you say, because I don´t really know a lot of phones, but how much It may cost?
It all depends on what country you are in and if the device has had a previous repair attempt on the problem. Get some online quotes and see if it is worth fixing.
댓글 달기
귀하의 답변을 추가하세요
Joseph Miguel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 56
