주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Backlight of iPhone 4 is dim after submersion
I took my iPhone in a lake a while ago, put it in rice, and tried to turn it on. It didn't work, so I ordered a battery from here, and it started working again. The only problem was the LCD backscreen was very very dim. I'm wondering how I can fix this problem.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Okay, my iPhone was submerged about a month ago. It wouldn't turn on at all and I put it in rice for about a week, and still no luck. So, I bought a new battery for the iPhone and replaced it. Luckily, the iPhone turned on, and I could see that the iPhone was up and running, but the screen was EXTREMELY dim. I had to use a light source (the beams coming off it) to FAINTLY see what was on the screen, but it was on!
댓글 달기
답변 2개
선택된 답변
Before you do anything else please follow the ifixit water damage guide.
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
댓글 달기
Put the phone's logicboard in IPA, this removes any corrosion and may even fix this
If that dosen't fix it, you will need a LCD/digitizer assembly
The backlight is in the screen, there is also a small chip that shorts sometimes and will need to be replaced, so look for a burnt or shorted chip under the shields, in fact, remove them for the IPA cleaning
Want more info?
http://forum.gsmhosting.com/vbb/archive/...
해당 답변은 도움이 되었습니까?
점수 0
댓글 10개:
Nick please take more than 1 minute to read and answer a question. You probably would give better answers that way.
is the backlight part of the lcd or is is a separate coil like on the 3gs?
good job on the editing
i thought so..was just trying to get nick to give a more thorough answer
Oh I see like mentoring the little grasshopper...:-) sorry for butting in....;-)
댓글 5개 더보기
댓글 달기
귀하의 답변을 추가하세요
chadderbox25 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,386
