주요 콘텐츠로 건너뛰기
1.6 또는 1.8 GHz dual-core 프로세서, 2 GB 또는 4 GB SDRAM, 64 GB 또는 128 GB SSD
187 질문 전체 보기
I've got many issues with my MacBook air
Hello, I hope u r all fine.
I have a 2011 11” MacBook Air with an i5 my OS is Yosemite 10.10.5
I have been facing many issues lately!
  • It’s booting up when I connect the charger
  • The keys T, Y, U, I & O are not working!
  • The rest of the keyboard are typing different alphabet letters! for example if I typed M it will appears like € and so on for the rest keys
  • When I boot up the hardware sign is shows off and I need to select it to proceed to the OS
I need help pls
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
All of these signs point to a blistered battery which is pushing up from below pressing on the keyboard. As the battery has failed your Charger is now the only means for the system to get power which is why the system starts up on its own.
You’ll either need to find a local repair shop who can replace your battery or you can do it on your own but you do need to be careful! When I get a system like this I take it outside to remove the bottom plate and the battery as soon as the bottom plate is removed the battery has nothing to hold it back. This is when the battery can rupture and that is when the batteries can catch on fire! Make sure you have a safe work area outside and don’t have any flammable material on or around you.
Here’s an example of a failed battery!
Here’s the iFixit guide to open the system MacBook Air 11" Mid 2011 Battery Replacement and here’s the iFixit battery you’ll need MacBook Air 11" (Mid 2011-Early 2015) Battery
MacBook Air 11" (Mid 2011-Early 2015) Battery 이미지
상품
$59.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
jan mina 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 30
