주요 콘텐츠로 건너뛰기
The 7th generation Honda Accord
97 질문 전체 보기
remote is not working
my remote is not working, even when i put battery
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
first thing double check the battery has been put in the right way round, honestly so many people put it back wrong. Check the buttons on the circuit board aren’t damaged or falling off and no signs of water damage.
This works with the generation before you car defiantly and may work for yours if it needs reprogramming, fingers crossed it works for you.
1.    Switch ignition ON.
2.    Within 4 seconds press the LOCK or UNLOCK button of the first remote transmitter.
3.    Within 4 seconds switch ignition OFF.
4.    Within 4 seconds switch ignition ON.
5.    Within 4 seconds press the LOCK or UNLOCK button of the first remote transmitter.
6.    Within 4 seconds switch ignition OFF.
7.    Within 4 seconds switch ignition ON.
8.    Within 4 seconds press the LOCK or UNLOCK button of the first remote transmitter.
9.    Within 4 seconds switch ignition OFF.
10. Within 4 seconds switch ignition ON.
11. Within 4 seconds press the LOCK or UNLOCK button on the first remote transmitter.
12.  The doors will LOCK and UNLOCK once.
13.  Press the LOCK or UNLOCK on all additional remote transmitters to be programmed.
14.  The doors will LOCK and UNLOCK for each remote transmitter programmed.
15.  Switch ignition OFF.
16.  Check operation of all remote transmitters.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It did not work. I changed the window botton on the driver's door. Since then, the remore stopped working.
댓글 달기
귀하의 답변을 추가하세요
yemitolaade 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 27
30일 전: 91
전체 시간: 1,655
