주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1585 질문 전체 보기
Can I swap my old hard drive into my new machine?
My 2011 MBP suffered from a dead short by the LVDS connector, which burned the board :-(. The problem is the cost of repair the damage was about as much as a replacement system, so I decided to get a identical 2012 instead. I’m not happy about why I had to buy it, but my hard drive is fine so I can make it like nothing ever happened by swapping the drive over.
Anyway, everything else about it is fine outside of the screen and board - including my hard drive so I still have plenty of reusable parts to pick at. I can drop the old hard drive into my new machine and be back where I am, but my replacement shipped with Sierra AND I updated to High Sierra (no APFS). To make it so I can run it for data recovery, I put Kapton tape over the LVDS connector and LVDS cable so I don’t have to worry about the short. Since my replacement is not on High Sierra, I don’t know what kind of updates I need to run to get the EFI firmware current or if it’s even an issue at all.
Once I install High Sierra and check the EFI is current, is it still possible to switch hard drives between systems with very similar hardware? I know it worked in the past but the EFI updates changed things dramatically.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 1개
선택된 해법
Hope I understood you corectly
A Macbook Pro 2012 with a High Sierra install can run a lower MacOS hard drive but a Macbook Pro 2011 cannot see a High Sierra formated (APFS) drive
해당 답변은 도움이 되었습니까?
점수 2
댓글:
What I want to do is remove the drive from the 2011, update the new one to High Sierra WITHOUT APFS (Not ideal for spinning rust) for EFI insurance and just have a newer machine. I'll take on the APFS upgrade when I get an SSD.
@nick yes you can take the old drive and do the update
의견 추가하세요
귀하의 답변을 추가하십시오
Nick 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 74
