주요 콘텐츠로 건너뛰기
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
42 질문 전체 보기
I can't open my controller because of a stripped screw
So just to clarify its not a first party gamecube controller Its the PowerA wireless GameCube controller for Nintendo switch. So the problem is i need to open it to fix the c stick cause when i face it up it sticks in the up position but i can’t open it because of a stripped Philips head screw and i can’t really open it at all
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
More then likely, you’re bringing out the drill since it’s a clone controller and not an original where the screws are good quality. However, what may work to get them out is to go one size up from the factory bit size - I am assuming Phillips because it isn’t a Nintendo product which would use the tri-wing screw.
If you need to drill it out, what you need to do is use the smallest bit you can get away with to break the head off, but leave enough room to get the screw stem out with plyers once you open the controller. Don’t go too far otherwise you will likely never be able to put a screw in that hole again. With a controller like this, you may be able to recover the use of the screw hole in question.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you! ill try the drill
댓글 달기
귀하의 답변을 추가하세요
Cilantro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 60
전체 시간: 2,147
