주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
3gs screen won't turn on at all
hi everyone, so my iphone touch screen wasnt working unless i apply some pressure on the top of the screen, so i opened the iphone to see if there was any loose connections, there was a loose connection, when i was reassembling the phone the number 1 connector snapped out and the screen turned off, then i reconnected it and it worked again, then when i was reassembling it, it snapped out again, but this time i cldnt make it work again, i tried hard resetting and disconecting the board from the battery, but with no luck, it can connect to itunes i can hear sounds the vibrate button works, but it doesnt show as a camera on the computer, what shld i do plz help ty in advance :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Try taking board out for an hour. Then reassemble. Make sure all display (1,2 &3) connections are clean/undamaged and secure( I know you said you took board off battery.. I think it's a temperature thing for th reset) try a restore.. The reset... Home and power usually works if it doesn't then I'd buy a new LCD.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Keep iPhone 3GS OFF when doing repairs or you risk damaging the LCD display or Logic Board Controllers of LCD display.
댓글 달기
귀하의 답변을 추가하세요
Ram015 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,473
