주요 콘텐츠로 건너뛰기
Canon's PowerShot SX200 IS is a 12-megapixel compact camera with manual controls, released in 2009. Features include a wide-angle lens, 12x zoom, and 720p HD video.
6 질문 전체 보기
My SD card won't lock. Help?
The SD card in my camera has stopped locking into place for no apparent reason at all. I havetried using a different SD card, so it’s a problem with the camera. It still works, because it is held down by the battery cover, but it’s a right nuisance. Can anybody help me?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
가장 유용한 답변
The spring mechanism on the SD card slot is broken. Canon solders it onto the primary PCB in the point and shoot cameras, so you need to repair the board or replace the entire PCB.
The problem is cost. In a lot of cases, board replacement tends to be as much as another camera (or an upgrade) so it is rarely worth doing. Because of that, you’re usually better off trying to solder a new SD slot on and hoping for the best. If that fails, time for a new camera.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Daniel Chamberlin 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 51
