주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Spilled tea on my MacBook, should I replace battery?
So I accidentally spilled tea on my macbook which prompted it to shut down. When I was cleaning the inside for battery stains, I noticed that unusual gel-like substances formed around this particular region.
I think the battery or connector is damaged. I’m able to use my laptop, but it relies completely on a charger now. Initially the inside looked like this:
My macbook had shells and keyboard covers at the time, which probably reduced the damage. Should I replace my battery?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Batteries do not like liquid. Change it out when you clean the board so you know there won’t be any battery problems. It already looks like the BMS is corroded too.
해당 답변은 도움이 되었습니까?
점수 1
댓글 8개:
I don't have a battery yet but I'll order one, so in the meantime I guess I'll remove the battery. Could you identify the BMS for me? Is that a separate issue that I should order separate parts to fix?
@djli - The BMS are the chips on the batteries logic board.
@danj I can already tell the electrolysis corrosion started from the photo. Game over in terms of not needing a battery :-(.
@danj Will a battery replacement fix the issue? I backed up the mac and took out the battery, but now it’s unusably slow.
@djli That could also be an SMC issue - hopefully it's an easy fix. Unless you had an EFI lock badly removed, it's not going to be an Intel ME issue. Try the battery first; the damage is done.
Did you use the stock 60W or an 85W adapter (upgrade)? These machines throttle without a battery unless you use the 85W adapter. I keep an Apple 85W on hand because it's nice to have for throttling hardware like this.
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 307
