주요 콘텐츠로 건너뛰기
Motorola released the Droid Turbo 2 in late October 2015. Model number XT1585.
sim card is block for call, sim is not from verizon
I am using Moto Turbo 2 Droid, in start it work well, now it is blocked for SIM card giving error that, SIM card is not from Verizon but before it not giving error of SIM.
unable to start calling i setup SIM on global setting.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Verizon requires that the device be owned 60 days, then the device will be unlocked. Otherwise, other SIM cards will be rejected. Also, is the card GSM? Verizon phones are only CDMA-compatible.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
60 Days owned? what that mean?
Yes the card is GSM.
Well, there's your problem. Verizon only uses a CDMA network, which does NOT work with GSM cards.
댓글 달기
If your SIM card is blocked for calling, it's most likely because it's not from Verizon. In order to make calls on a Verizon network, your SIM card must be activated with Verizon. You can do this by either purchasing a SIM card from Verizon or by transferring your existing SIM card to Verizon. If you have an existing SIM card that you'd like to transfer to Verizon, please contact us and we'll be happy to assist you.
See more info https://grouphowto.com/verizon-sim-card-...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kamran Shah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 393
