주요 콘텐츠로 건너뛰기
Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 질문 전체 보기
Why my Apple TV can't handle remote controlling?
Hy everyone!
I bought two days ago an Apple TV (third gen) without the original remote controller. I have two other remote controllers at home an OEM one and an aftermarket one. The problem is that after the reset and before the reset the Apple TV can't handle the remote controllers. And this is the problem with the remote controller application on my every apple device that have of course newer OS then the iOS 7. The remote controller application can’t find the Apple TV that was on the same internet connection with my other Apple device with the remote controller app.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
2 댓글:
Do you have an older IR Apple remote? See if you can turn it on with it.
@danj I don't have an older remote :/
댓글 달기
답변 1개
Time to buy the needed Apple remote Apple TV Siri Remote. You should be able to find a used one which should be cheaper.
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
When I had this issue, I had to re-pair my remote to the Apple TV. Here’s a video on how to do it.
https://www.youtube.com/watch?v=Aw20w-ZS...
The 3rd generation uses a different remote than the first & second generation. The older one was strictly IR. The Siri versions offer dual function IR as well as Bluetooth. But once linked to the given Apple TV you can't use a different Siri remote without resetting the Apple TV using the IR only Apple remote.
댓글 달기
귀하의 답변을 추가하세요
Norbert Jauch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 77
