주요 콘텐츠로 건너뛰기
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
112 질문 전체 보기
I dropped the MacBook on it's aux port and it is now deformed.
Hi,
I dropped a new macbook pro when unloading the car after a skitrip. It was in a protective cushion, but it fell on a corner and I think it hit the harder zipper area of the casing (the zipper area also broke there). The fall slightly deformed not the bottom case of the laptop, but the case that holds the keyboard, touchpad, etc…
The casing got deformed just around the aux port so that I can’t plug headphones in anymore. I don’t know if it also broke the aux port itself, but I would think not.
Does anybody know how hard I F’d up or is it quite possible to replace this casing?
Thank you for any help!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Ouch! Did you take out AppleCare+ extended warranty? If you did that will be your cheapest way to get this fixed.
Getting the uppercase replaced is also possible. You’ll need to get the correct version based on the keyboard you are using, as an example review this listing [B661-12993|13” MacBook Pro - Top Case & KB UK] you’ll need to contact TheBookYard to find out when they expect new stock of the version you need. I’ll warn you it will likely be awhile!
If you can live with the damage you could get a USB-C to headphone jack DAC adapter so you can plug in a headset or external speakers.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hello,
No I haven’t taken any extra warranty. I think I will probably have to start using a USB-C to jack DAC adapter then indeed. Might pass by some repair shop and see how much they would bill me to get the top case replaced, since I’m having trouble finding it online. Would it even be an easy repair? I know my way around a laptop, having fixed some macbook batteries, but haven’t tried my hand on any advanced stuff.
댓글 달기
귀하의 답변을 추가하세요
Stefaan De Waele 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 126
