주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
Why is the charger orange when battery is fully charged
Battery shows full charge until charger is hooked up, then the battery shows 99% with the charger going from green to orange
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The battery is still telling the charger it needs power. I would make sure you are using the correct charger for the system and check the cable and MagSafe connectors. Review this guide: Apple Portables: Troubleshooting MagSafe adapters. Be aware there are a lot of fake chargers out there! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth. Make sure you got a real one I’ll warn you its not easy to tell the real from the fakes! The only way is knowing the source where you buy it, Apple is the only one I trust.
Install this gem of an App so we can see what happening CoconutBattery post a snapshot of the main window here for us to see 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
re: charger.
I am using Apple chargers only.
All are producing the same results.
Could the battery be faulty ?
Let's see! Post the CoconutBattery snapshot so we can check it.
댓글 달기
귀하의 답변을 추가하세요
Dan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 41
