주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2660 질문 전체 보기
My phone only works when charging
I have dropped my phone a few times and the screen cracked a little. The thing is that about a week ago i was using my phone and it suddenly started lagging and being really slow, but when i plugged it in it worked perfectly. It still works when not plugged but it lags and slows down a lot. Also some times it turns on and off suddenly. I have had my phone for about 6 months and i really don’t know what’s going on. I have tried from just turning my phone off to reseting the whole thing as it was brand new. I honestly don’t know what else to do. Please Help!!! Also to clarify, the battery is working fine when not plugged in.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
You probably broke more than just the screen when you dropped it. Best thing to do is have the screen repaired and have them look for other issues when the screen is off the phone. Good luck.
댓글 달기
답변 2개
You likely need a new battery. Go into your devices settings app, scroll and find the Battery section. Tap on it and then select Battery Health. It will then tell you what percentage it is at, and if it’s slowing it down to prevent the phone from shutting down. If it’s below 75%, it should almost certainly be replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I’ve had similair symptoms with iPads in the past. Sometimes a calibration of the battery is required after some amount of time.
You could try to plug it in the charger, then hold the home button and the power button together. Hold this untill you see the apple logo when its starting up again.
Just a thought..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Julia Martinez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 19
전체 시간: 594
