주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
176 질문 전체 보기
Broken microphone, where to find replacement? What's the part number?
In step 15 of this iFixit guide, you can see the microphone being removed from the device:
iMac Intel 21.5" Retina 4K Display 2017 Teardown
I’m trying to find this part. Anybody know where I can order it, or what the Apple part number is?
Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Is this the part you need? iMac 21.5" Microphone, Apple P/N 821-01020
해당 답변은 도움이 되었습니까?
점수 1
댓글 9개:
Yes! Thank you!
Mine is broken too, how do remove it from the imac chasis? Just pull it off gently ?
what's the tecnique to remove it ?
Follow this guide iMac Intel 21.5" Retina 4K Display (2017) Display Replacement to get the display off and then peel it off the case.
Most of the time people forget the needed gap in the adhesive tape you need to create before applying it! So its not the mic that's messed up, its just the needed hole is blocked! From the displays tape.
I'm quite sure I've done something harmful to the cable or connector or the microphone itself
I did 2 errors (I guess)
1) I removed the connector without opening the latch
2) when I was remounting the logic board I discovered that I had pushed the the microphone flat cable under the chassis and under the board
I removed it again and secured the flat this time outside with some tape
now the systems sees a microphone connected
but there is no input: is dead
I reopend to retest the connection/connector, and reseat but not working...
댓글 4개 더보기
댓글 달기
Hello
I am looking for Apple Part 821-01072-A, the microphone for iMac 2019.
Is it the same part as in 2017?
Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
@danj Thanks Dan but out of stock
Is it possible to use an Apple laptop mic instead, i would like an integrated solution as much as possible
Found a use 2017 microphone on ebay but no clue if something is wrong with my connector?
Also tried with a 21 inches 2017 microphone brand new and no luck, my mistake was that i forgot to open the latch before pulling when removing the logic board the 1st time :(
No you don't have a cable issue, you damaged your logic board! Some how you pulled off one of the SMT devices just to the bottom right corner. Do you see the two silver pads something was mounted there.
I don't have a schematic or boardview for this model right now so I can't tell you what it was. I'll need to hunt one down if I can.
댓글 달기
귀하의 답변을 추가하세요
Cero 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 2,040
