주요 콘텐츠로 건너뛰기
2018년 9월 21일 출시. Models A1921, A2101, A2102, A2104. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S Max"로 발음합니다.)
373 질문 전체 보기
When I am talking to someone on the phone, its hard to hear them
When I am talking to someone on the phone, I can barely hear them and vice versa. I have checked the volume button , went into the settings and turn it up all the way. I don’t know what else it could be.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Firstly make sure your speaker mesh on the earpeice is not blocked if you take a look under a magnifying glass you can normally see it's clogged up.
If so clean with a fine pin and don't push to far down or you go right through to the speaker and damage it.
Then look at the bottom of the phone and check if you have the same problem and clean.
Secondly rule out firmware bit could be a bug in the software.
Back up your device and the activate without putting you backup on and see if that helps.
Thirdly if none of the above options work.
You make have a board issue.
Cheers
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
amyhenschen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 35
