주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
140 질문 전체 보기
Fans at full speed and don't stop even if I shut the mac mini down.
Hi! My mac mini 2007 (2.1) fans run at full speed and do not stop even then I shut down my mac mini. They only stop if I unplug it.
I ran the AHT and it shows 4MOT/1/40000003: Master.
Any suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The error 4MOT is a fan error. Apple uses a fan which has a tachometer within it which reports to SMC the fans status which in this case has failed. SMC will push the fan to the max as it wants to make sure your system is not overheating,
You could try to clean it with a small soft paint brush and a can of can’ed air. Most of the time they are just burnt out and need replacing Mac Mini Intel Fan (06/07), Apple P/N 922-7317 - Used. Here’s the guide you’ll need to follow Mac mini Model A1176 Fan Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Dimitrios Tsounis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 50
