주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
772 질문 전체 보기
Battery for EARLY 2016 MacBook Pro 15 inch?
I have an early 2016 MBP 15inch with a swollen battery. All I find for kits is for late 2016. Are these the same? If not, any thoughts on how I can replace my battery?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개
Apple didn't make an Early 2016 model, all they did is offer an updated Mid 2015 model until the touch bar models came out.
Double check by accessing your systems S/N under: About This Mac and looking it up here EveryMac - Lookup
Thanks. I wonder why everyone calls it late 2016 then, and not just 2016? By the way, your link doesn't work.
It works, It gets you to a web page to plug in your systems S/N to find your system. I just checked.
It does. Didn't a minute ago. Thanks.
@sdeban - I suspect, session time outs due to overloaded Internet.
댓글 달기
답변 1개
가장 유용한 답변
Here’s the 2015 model battery replacement guide MacBook Pro 15" Retina Display Mid 2015 Battery Replacement
And here’s the 2016 model battery replacement guide MacBook Pro 15" Touch Bar Late 2016 Battery Replacement
You’ll find the needed battery replacement kit for your system which ever one you have.
MacBook Pro 15" Retina Display Mid 2015 Battery 이미지
안내서
난이도:
어려움
45 minutes - 2 hours
MacBook Pro 15" Touch Bar Late 2016 Battery 이미지
안내서
난이도:
어려움
1 - 3 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Great. Thanks! Do you know if the torx driver problem that someone commented on with the kit was solved? I'd hate to get 60 steps into the process to discover the tool doesn't work.
댓글 달기
귀하의 답변을 추가하세요
Stephen Deban 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 137
