No signal after repair
Hello,
Having put my s7 in for a repair it came back with the following issue, it will not connect to any network or radio tower, the signal triangle has a little x on it. I tried evertything software, took it back to the shop, who fobbed me off for half a year saying the antenna was part of the screen and hed put a uk screen on my us phone. Apparently that is untrue.
The shop dont want to know now, so I took the phone apart. All i can find is that the ‘Antenna Module’ at the top is snapped in two.
My question- before i bin the thing- is the broken module responsible? To me it just looks like a bit of plastic with metalic stripes on it- the stripes are undamged…
Any clarification would be awesome.
thanks
Paul
좋은 질문 입니까?
I'm sorry to hear you had to deal with a shady repair shop, I see this happen all of the time. Would you mind posting some pictures of the damaged components?
Jesse Hooton 의
Hi Jesse, thanks for your commiserations, it's appreciated.
I've put the thing back together now, and don't know how to add a picture here, but it's the same part as is here. It's now in to pieces though :(
https://www.google.com/amp/s/www.parts4r...
Paul Williams 의
I figured it out, you can just make out the diagonal snap between the two closest metallic looking bits.
Ta
Paul Williams 의
Hi, any advice? Would the snapped bit pictured stop me getting cell reception? I still get wifi
Paul Williams 의
id have you check to see if you can still get imei and or wifi bluetooth at a close distance to check imei diaL *#06# if you get that then it is some sort of antenna issue
Kyle Pettigrew 의
댓글 8개 더보기
