주요 콘텐츠로 건너뛰기
Mac 하드웨어 - 외장 드라이브, 전원 어댑터, 케이블, 변환기 등 Apple에서 제작한 Apple 기기와 연결되는 모든 것
1112 질문 전체 보기
DVI to ADC adapter failure, it's a AC/DC 90w, M8661Z/B, 100-240V
hi ifixit,
first thank you for your great work !
my problem: with one of my 2 apple dvi to adc adapters (AC/DC) seems to be something wrong ...
tha cinema display goes on and off in different times.
not the apple-display is broken, as if connected to the other apple adapter all ok.
please tell me how to open the adapter-case to have some electronictech to look which part is "broken".
thank you best regards
sascha
p.s. sorry for confusing, but it's the ac/dc adapter 100-240V
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
The way your adapter is working I would think one of the wires is making and breaking contact. The only way I know to open the adapter is with a deremel tool cutting wheel. When through with the repair you would need to tape the cover back together. The end result is ugly and unreliable because you can never quite secure the wires the way they were. Also if you are going to pay someone else to do the repair it would be less expensive to purchase a new adapter. Link provided. Good luck whatever your decision.
http://eshop.macsales.com/item/Belkin/F2...
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
Here's one for $5.50 if you don't want to tear your's down: http://old-macs.com/pages/Cords_Cables/A...
Ralph's link is fine but the price is $31.00
해당 답변은 도움이 되었습니까?
점수 2
댓글 9개:
Always happy to see a less expensive source. +
thank you for responses but i made a mistake as my adapters are these big white boxes with ac/dc ..
any numbers on these boxes?
Hi Richard, Here's a link to one of these on ebay---if it were me I'd use your $5.50 unit. I really can't tell the big advantage to this unit but I believe my original solution stands. Cut it open with a dremel disk and repair if possible the bad wire.
http://www.ebay.com/itm/APPLE-DVI-ADC-DI...
ouch, pricey stuff
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
shk747 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,354
