주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1198 질문 전체 보기
iPhone x turns on, but the screen is black.
I was replacing the screen when i tested it befire putting it all back together, it worked perfectly. I put the bracket and everything back only to find the screen no longer works. Please help, any answer would be great!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
tested my old display on it and it wont work either, possible logic board issue?
댓글 달기
답변 1개
Hi Shane,
Did you disconnect the battery before you disconnected the display? If you did, it could be you fried (damaged) your backlight fuse on the motherboard. If you’re not entirely sure, you could check if your phone still works by standing in a dark room and pointing a flashlight at your screen when you assume it should be on. If it still works you can see an apple logo or your lockscreen (if you look really good). If you can still see something on your sreen (but only with the flashlight in a dark room), your backlight needs to be fixed. If this is the case, it could turn out as an expensive repair.
I hope my information is clear.
Let me know if you need more help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shane Grant 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 416
