주요 콘텐츠로 건너뛰기
A USB (Universal Serial Bus) cable is a common type of cable used to connect devices such as computers, smartphones, printers, cameras, and other electronics. It is designed to transfer data and power between devices, and is often used for charging devices as well.
15 질문 전체 보기
Can I re-solder a lightning cable?
The cable is broken near the connector, can I re-solder it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
It’s not something I would recommend!
If the cable is physically attached to the device can you open the device to get to the points the cable wires are connected too?
If you can I would just replace the full cable.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Hutchoo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 23
전체 시간: 767
