주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
1631 질문 전체 보기
home button not working
I have bought the replacement home button for my iphone 7, my touch ID sensor does not work. I know touch ID functionality will not work but this button should function as a normal home button. I restored the phone after the replacement and the button does not work. I tried unplugging the cable and plugging back in and still not working. did I get a faulty home button or am I missing something?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Essential Electronics Toolkit
Small Toolkit. Big Possibilities.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
답변 2개
가장 유용한 답변
Before you send the home button back I would check the home button flex coming from the screen to the logic board. Check it under magnification especially at the 90 degree bend and look for a small tear. This is the most common reason the iPhone 7 home button fails after removing the screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
is the flex available as a part somewhere? can it be replaced? my button stopped working too after battery replacement. Have visually checked for damage, couldn't see any. But haven't checked with magnification yet. Will try this. thanks.
의견 추가하세요
Some replacement buttons are not compatible with the 7 and above. Where did you source your replacement from?
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I purchased the home button from ifixit for the iphone 7.
Man I've heard nothing but issues from ifixit's parts lately, although I've never used them. Try ordering the JC one from Mobile Sentrix. Look for version 7. It's a little more expensive at $10 but you should get the home button functionality restored.
thanks, I am going to return this one that I bought from ifixit and try that.
Good luck! I know in the past you could replace the home button on the 6s and below and you'd only lose TouchID.
의견 추가하세요
귀하의 답변을 추가하십시오
tbei25 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 24
