Why is iPad Air (A1474) screen unresponsive
My iPad was run over by a car 2 months ago but ended up slightly dented and needed a new LCD screen. I just replaced the LCD screen and kept the original digitizer and it was working just fine for about a day. It randomly just stopped being responsive to touch.
The home button stopped working as well, so I replaced the digitizer with a new one (purchased from RepairPartsUSA) only for the touch to still be unresponsive but home button works.
I then went back replaced the new digitizer with the original to see if it made a difference and the home button worked again just fine but still no touch response.
I made sure all cables were properly connected and lined up correctly. I even did a hard reset/restore and update and still nothing.
Should I try a new digitizer just incase the two I have are just faulty or should I chop it up to being another issue?
좋은 질문 입니까?
Check around where the connectors are you could have knocked off a component.
daniel 의
@tech_ni I checked, but I am not seeing anything missing or out of place
Mariah 의
