주요 콘텐츠로 건너뛰기
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
24 질문 전체 보기
Fan starts then stops, no power, caps lock blinks slowly
Hi,
Model is X0Q77ES, 250GB SSD, Model 250 G5
What I’ve tried so far;
  1. Windows Key+B and Windows key+V BIOS and CMOS resets. Didn’t work, fan whirred then stopped, then caps lock blinks. Have to remove battery to stop this
  2. Created BIOS recovery USB from HP Support. Inserted in USB, tried turning on normally and then turning on with WK+B held down. Same result as previous
  3. Went through HP virtual assistance confirming AC adaptor works etc.
Have ended up fairly confident this is a major hardware fault and now requires investigation. On reading, I’ve picked up from various webpages that the ram or hard drive could be the problem.
Found a few answers in ifixit about rotating ram, gpu reset with hairdryer etc. etc, but nothing exactly the same as my issue, so figured I’d put this out there to the experienced users and ask for help.
I’ve been around computers a long time and happy to take things apart, but a novice with laptops and need some guidance for next steps please.
Thanks
Harvey
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
가장 유용한 답변
Hi @hkuk2020 ,
Is there a pattern to the Caps lock light blinking i.e count the number of blinks before it pauses and then repeats ?
If there is one, use this link to find out what the pattern means.
For your model scroll down to Computers released between, before 2015 (I think).
Here’s the maintenance and service guide for the laptop in case you need to dis-assemble it to gain access to anything.
It details the pre-requisite steps and then the procedures to remove/replace all the components. It also has the part numbers if you need to replace any. Just search online using the part number only in the search term of your browser to get results for suppliers
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Hi @jayeff ,
Thank you for the quick response, there is indeed a pattern. One slow blink, pause then repeat. I'll follow your steps now to see what else I can figure out and see if this helps me resolve the problem. Hopefully my next comment will be to advise the fix and say thanks.
Best
H
Hi @jayeff
Okay, so I am back again. Having followed through the various links you kindly sent, the conclusion is that the CPU has failed. When reviewing the main document, there does not seem to be a separate link for the CPU? The only code I can find is 858579-601, which is the Windows 10 motherboard with the i7-6500U chip.
On the HP Partsurfer website they want +£850 for this part. I only paid £500 for the PC.
I'll keep investigating, but open to further info or ideas.
Thank you
H
@hkuk2020 ,
The CPU is hard mounted on the motherboard that is why there is no replacement part specifically for it. The whole motherboard needs to be changed.
Last throw of the dice is to try a power refresh to check just in case the BIOS has been scrambled for whatever reason. It only takes a little while.
Disconnect the charger if connected, remove the main battery from the laptop, remove the RTC battery from the motherboard, (use the manual to view how to remove the RTC battery -p.63 and remember the orientation of the battery for when you go to put it back in, usually it is +ve on top). If you have a DMM (digital multimeter, check the voltage of the RTC battery while it is out. If it is <2.6V DC replace it with a new one. They're a common battery available most everywhere. Look for the battery number on the battery mostly they are CR2032 but it may be different. You can still put it back in if it is <2.6V but it will need to be replaced as if it is too low BIOS corruption can occur. The battery is non rechargeable and usually has a life of 5-7 years
Then press and hold the laptop's Power button for 30 seconds and then release the button to discharge any residual power from the motherboard and thereby restore the BIOS to default.
Reinsert the RTC battery, reinsert the main battery, connect and switch on the charger and try to turn on the laptop.
If still no good it is a motherboard problem.
Commiserations
If the part number you quoted is the one for your motherboard (look on the motherboard itself perhaps for the part number to verify) search online using the "part number only" to get other suppliers
@jayeff
Thank you for your help, I'll hopefully get around to trying this today.
After jayeff's steps you may want to take out HDD, reseat RAM, clean fan, etc.
Here's a YouTube video showing how to:
https://www.youtube.com/watch?v=ZGyD-ZJQ...
Quite well done, I thoght.
If the fan is really dirty or not spinning it could be the CPU over heated but I'm guessing HDD (especially if mechanical - I'd take the HDD out and connect to USB adapter and try on another computer)
or RAM defective or improperly seated - swopping around, etc. ????
Of course you didn't drop it. Right?
I think a corrupt BIOS is also a possibility.
https://support.hp.com/au-en/document/c0...
The USB recovery drive is a good step if all on the laptop is corrupted. . .
But you tried all that????
But have you tried it with the HDD taken out as HP says, "If HP BIOS Update does not display or the issue persists . . . there (could be) is a hard drive issue." Worth a try.
Good luck!
4에 댓글 더 나타내기
의견 추가하세요
귀하의 답변을 추가하십시오
harvey.kempton 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 87
전체 시간: 1,311
