After Display change display is only white
Hey after i changed my display, when i startet my iphone it was only white.
When i try my old, it works so what could it be ?
Greetings
좋은 질문 입니까?
Greetings
좋은 질문 입니까?
Was the phone off when you did the exchange? If the phone was just asleep, it can sometimes need to be reset to work with a new LCD. Turn the phone off with the working LCD, then do the swap.
If the phone was off and power cycling doesn't fixing the problem you may have bought a bunk Display. Where did you buy the Display? If it was from us, contact sales@ifixit.com to set up a return.
해당 답변은 도움이 되었습니까?
No need to reinstall old LCD!
In my case, the iPhone needed to be reset. Press down both Home- and PowerOn-Button till the apple appears (about 15 seconds).
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 414
댓글 2개
http://www.ebay.de/itm/Original-Apple-iP...
this is where i got it
Simon 의
should be ok. you definitely have a 3g and not a 3gs? They look similar..but the connectors don't fit.
pollytintop 의
